E
ed-ectrician
So i get to a job today and find this. Those three on the right are flipping live! I called uk power networks and he was trying to contest and say the problem wasnt theirs. I'm sure, as this is upstream from the meter, it's theirs. Any wise words from any of you? The bloke on the fone said if they get there and it's not their prob they turn off all power to the flats from the street and i have to go and sort it. Great...
Hopefully the lads they send out will make it safe (even sticking in 3 carriers will make it a hell of a lot better! - i dont have any or i would've done this myself) and not be jobsworths like the bloke on the phone!
Thanks,
Ed
they cant actually switch the power off with out a written notification , those cut outs are prehistoric , house doesn't belong to fred flintstone does it ,wouldnt be hard to disconnect the RH cutout
Call them on an emergency! Should be with you within the hour.
Def their equipment if before the meter.
Is this room locked?
They cannot dis in street without written notification,EXCEPT in an emergency!Plus the amount of work needed to dis the supply,dig up street etc would be ridiculous.If you look at the photo again you will see that there are 2 sets of terminals on the bottom of the fuseholder,if you were to remove the l1 fuse in first carrier there will be 2 cables,one from the service cable and one a strap going to l1 on the second carrier bank.all the dno have to do is remove these links simple as that.
They cannot dis in street without written notification,EXCEPT in an emergency!Plus the amount of work needed to dis the supply,dig up street etc would be ridiculous.If you look at the photo again you will see that there are 2 sets of terminals on the bottom of the fuse holder,if you were to remove the l1 fuse in first carrier there will be 2 cables,one from the service cable and one a strap going to l1 on the second carrier bank.all the dna have to do is remove these links simple as that.
Not quite as easy as you suggest!! Those cables are set in sealing pitch, with maybe just a couple of inches of exposed cable. You would need to warm that pitch up significantly, to stand any chance of moving them!! lol!!
