A
A Carter
I have been a electrician for 5 years and have been subcontracting to companies for my whole carrier, I have my 2391 and was
thinking about doing my own work but I just need to know if Have to join a company like NICEIC to give out test certificates or
can I just do that on the basis that Im a competant person?
for domestic work, if it's notifiable, you need to involve building control. if they are already involved, e.g. new build, extensions, then usually a copy of your cert. will suffice. if, however, you are doing a job invilving new circuits etc. where no building work is involved, you need to notify them. their cost is extortionate, so you are better off joining a scam, nic, napit, elecsa, £400+ per annum.
Do you plan to do notifiable work? If so you would need to join a scheme, currently Stroma are the cheapest.
If you just want to do EICR's then scheme membership is not necessary.
contact elecsa for details. they are part of ECA and would seem to be the most electrician friendly robbers going.
Ok ill have to look into joining one then thanks
A quick tip for the forum use, on the brown bar below each thread is a "thanks" button and down in the bottom right corner of the thread is a "like" button. Use these to show your appreciation.
cobblers. as long as he's got 17th, they'll take his £444 gladly.
- - - Updated - - -
Can anyone explain to me why it is thought that we all have to join a scheme as the regs only require that a competent person is enough. Don't be drawn in to the myth that you have to join anything there is no legal requirement and not a court in the land that can convict as long as the work is done properly and the appropriate forms and records are kept.
All true but the simple answer to the question is NO. Some LABC's will let you notify and sign off direct but there's loads of scams you could join. It all depends on how much notifiable work you are taking on and if your customers will pay the extra to notify to LABC. Quite a few of the sparks round here do this and add an extra 80 quid on to sign the work off.
I could drive a car before I passed my test. Did I waste my money?
aye...stroma are the cheapest....but what a set of turnips...lol.....i went to see em ..oh a year back......they just sounded like a set of divvys..lol...
perhaps they`v sorted themselves out...i dont know...lol..
