Hi All
I hope this topic makes sense for this forum and somebody can help me to understand.
This is what I understand (please allow numerical approximations):
1. Electrons move in a conductor at a speed anywhere near the speed of light.
2. Electrons gain actual velocity (drift) only when supply is ON. Propagation of EM field is about 270.000 km/s.
3. For DC, drift velocity can be calculated.
Now, am I right to say that, in AC, actual average velocity is zero? That's because in a PERIOD, electrons move back and forth. I could calculate the drift in half a period, but in a period would be zero. Correct? This means there is no actual transmissions of electrons from source to load, right?
Under the assumption above, why we keep talking about "power transmission"? As a matter of fact, there is nothing moving from source to load. Electrons simply move back and forth while performing work.
Also, under the considerations above, can anyone explain the concept of "reactive power going back and forth from source to load" in cases where power factor is lesser than 1?
Thank you very much in advance!
