S
Snodge
Hi everyone, I'm new to this forum and I have a strange question.
Ok so back when I was 15 I plugged a second hand dvd player into an extension lead which had nothing else plugged into it (UK 3 pin).
The plug had no cover on the back and therefore when I pushed the plug in the pins got pushed back out of the casing.
(This is the stupid part; other than not having the plug socket switched off) I used my thumb to push the top pin into the plug socket then used my right thumb to push the right pin in, and my left thumb to push the left pin in (I still had my right thumb on the right pin).
Regardless to say I got electrocuted which felt like a crazy vibrating numbing feeling and apparently I shouted at the same time.
Story-time over, I want to know if because it was a dvd player did I get a different current/voltage passing through my body than if I was doing it with a washing machine/other electric item? Or is it a standard current/ voltage from mains as if there was no appliance attached to the plug?
Just want to know what electrical properties went across my body.
