Discuss Elex 2008 in the Industrial Electricians' Talk area at ElectriciansForums.net
Reply to Elex 2008 in the Industrial Electricians' Talk area at ElectriciansForums.net
Hi, Ignoring the appauling conductor terminations which I found, in the background of the photo you can see a really odd neutral tail terminated...
Hi guys, I'm trying to find a definitive answer on the use of 1.5mm 2C+E for power points in a transportable structure which is fed by a 15A inlet...
Anyone know what the going rate is in Australia for Adult apprentices?
Hi all, I'm wondering if there is anyone one here that has or knows anything about working as an Electrician in the UK with Irish qualifications...
Hi. Has anyone ever taking a feed from an outside light to use as a spur to fit an outside plug to plug in a plug in ring camera. The only feed...
