G
Grant Naylor
A client has 8 ELV down lights in a ceiling in an single story extension on the kitchen, so there is no roof space.
There are 3 switches 1 controlling 2 ELV and the others each 3 ELV lights.
2 ELV circuit works fine
3 ELV circuit 1 - one light still works
3 ELV circuit 2 - no lights working
Main problem - can't access the fixed wiring the lights only pull out enough to allow the transformer to drop out along with the ELV but that's it, no J-Box.
I only had a quick look and not yet tested if any volts after the transformer, but I would assume since some are still working more than likely the transformers have stopped working on the broken lights. Bulbs have apparently been replaced and nothing working.
Not really done much with ELVs but not too optimistic for these.
My only thoughts are:
Confirm bust transformers as expected
Isolate
Snip out the broken transformers on the LV wiring side
Terminate LV wires into connection strip
Voltage test to ensure switch wire is live
If switch wire not live:
Isolate
Chocbox cover over the strip.
Place back in the ceiling space and put the ELV accessory back in place disconnected.
If switch wire live:
Isolate
Terminate new transformers into connection strip
Put back in ceiling
Should be sorted
That sound reasonable? If switch wires turn out to be dead I can't see a way of getting them sorted out without pulling the ceiling down.
However, this sounds like a bit of a minefield in terms of what could be the issue. I only really get to see if the fixed wiring is bust after snipping off the transformer to get to the LV wiring. I don't want to be responsible for having to fix something I can't get...
Any thoughts?
Isolate
Isolate
Isolate
Put back in ceiling
Should be sorted
Any thoughts?
