Suffolksparky
H, I know this has probably been covered a thousand times, but just interested to here what people wouldn't of on this set up feeding a brick garage with steel frame And sprinkler system that will need bonding
TN-C-S (200amp) 70mm tri-rated tails (50mm Earth)(25mm bonds)
DB1
Out off DB1 with 16mm 3core via 45amp mcb to garage DB
now should this garage be put on its own TTsystem with the earth wire isolated?
or should I drag 25mm bonds from the steel and water to the main building MET
if anyone can point me to a reg or info on this it would be much appreciate
