- Reaction score
- 118
Hi any off you guys using these looking for any sort of feed back , seems a descent product , or do any of you use something else ?
Discuss Grip it in the Electrical Tools and Products area at ElectriciansForums.net
I can second this recommendation. They're very good I have hung my TV on the wall using them.For a really solid fixing in dot and dab, I use Dryline Pro:
DrylinePro - Plasterboard wall fixings for drylined walls
If it's something lighter, an ordinary large plug will do.
Have always used hollow wall anchors with an applicator tool like these
Hollow Wall Anchors | Anchors | NoLinkingToThis
Really easy to use and only leave a small hole if removed (just use a drill bit for metal)
I see these grip it fixings on dragons den...peter jones pulled the radiator off the plasterboard wall.
Don't bother, they are expensive and difficult to install correctly every time!!
And the guy doing the pitch blamed it on the plasterboard being damp
That was my thought when I saw them in a plumbers merchants,
I have never used them mainly due to the cost but also the installation of them looks over complicated compared to the many other fixings out there that will do the same job
Reply to Grip it in the Electrical Tools and Products area at ElectriciansForums.net
Thanks for visiting ElectriciansForums.net, we hope you find the Electricians Tools you're looking for. It's free to sign up to and post a question yourself to find a tool or tool supplier either local to you, or online. Our community of electricians and electrical engineers will do their best to find the best tool supplier for you.
We also have a Tiling Tools advice from the worlds largest Tiling community. And then the Plumbers Forums with Plumbers Tools Advice.
