Hi and thank you for having me in your forum.
My background is more electronics than electrical but I'm reasonably competent with UK mains, however this has me baffled.
I'm confused by a RCBO which I got the other day to feed an appliance that draws like 40A peak.
It has a Live input at the bottom, which goes to the L bus.
At the top there are L out and N out screw terminals, and also a blue, hard-wired, flying lead, with a crimp terminal end, which I gather goes to the N bus bar.
So if the circuit goes directly into L and N out, doesn't that mean that ALL the return current on the neutral side is going to go via that tiny flying lead?
That can't be right, surely? It's a 40A C rated RCBO, and it just doesn't feel Iike that thin wire is safe for 40A.
So I must be missing something, as there doesn't seem to be any other neutral line closing the circuit. And no instructions supplied with the device.
Can anyone explain what's going on?
Cheers!
Cheers!
