T tony345 Nov 17, 2009 #1 Does any one know where i can get ohms converted to milli amps tables i would be very grateful if you coild post me some links cheers.
P Phil Mumford Nov 17, 2009 #2 mA=V/1000*R - you need to know exactly what voltage you are dealing with to get the answer. You can knock up your own on excel fairly easily for different voltages. Last edited by a moderator: Nov 17, 2009
steamboatwilly ~ Arms Nov 17, 2009 #3 Hi Tony, There are a few online calculators such as http://www.tlc-direct.co.uk/Technical/Charts/OhmsLawCalculator.html You'll need to adjust the decimal place of course. Assume 230V. You can use Excel, get a few readings for a range of Amps and the interpolate? That way you could generate your own table.
