I'm making my way through the design project, having trouble with the pool layout. I've had a look through other posts on these forums but cant find specific advice. I've chosen my light fittings, built specifically for pools and indirect lighting. I've chosen 7 as theyre wall mounted uplighters, giving plenty of diffused light. Main issue i have is the circuit lengths, I have the lights arranged around the wall, one each end, 2 on each side and one over the plunge pool. Both ends and the two on the side with equipment room etc have emergency packs to light access/ side rooms. Brief says circuits should be roughly 30m, I can get to 31ish not including any drops/ rises for accessories etc. Circuits are currently grouped as 4 emergency main lights with time switch, 3 standard main lights and time switch, then the side rooms (these include emergencies). Theres plenty of examples of other peoples frawings on here and elsewhere online and at a glance they appear to be well over 30m (pool is approx. 8.5x17.5m)
Am I overthinking this or do I need to split these circuits down further? Seems crazy to have one or two lights on a circuit for the sake of the brief. For various reasons My path to being an electrician has been a bit back to front so I have no trouble with the calcs etc after but i cant seem to get past this.
Also, has anyone got a recommendation of a program I should look at for doing this digitally(visio/libreoffice?) So far I've been physically drawing it out but my sheet will only take so much rubbing out..
MoeJurphy,
Electrical Courses
