Hi,
We have just had a house survey done on my late parents home. The surveyor has picked up the fact that main electricity feed to the house comes in to the kitchen and the meters are attached inside the kitchen cupboard. This kitchen was fitted professionally and electrics completed by an electrician around 15years ago.
The houses were built in the late 60’s and once had a coal porch (?), side entrance. Probably 95% of this type of house have blocked this doorway and extended their kitchens in to the space. My family did this at least 30years ago and the same kitchen layout has been there ever since.
So the issue being that the main outside wall was knocked down and therefore the electricity feed is located on the cabinet, where the wall was removed. This has been the case through several kitchen changes and never seen as an issue. Even having a new smart meter fitted, no issues by the fitter.
Fast forward to today when having a survey done, it’s been flagged as an issue. Clearly the main feed cable isn’t long enough to be able to move it to a wall so where do we stand? Every house in the area that’s made this change would have the same issue and therefore assume theirs are attached to the cupboard.
Thoughts please?
Thoughts please?
