Ive got a problem with my own hottub. Worked perfectly well for years. Its a Candian Spa hard case type. Not an inflatable lazyspa....
I drain it down properly over the winter, sucking any pools of water out the pipes with a vax.... clean it and refill 2 or 3 times every summer.
Short version... .it is tripping the 32A MCB of the downstairs socket circuit. Board is a split RCD... only the sockets are off the RCD side... lighting is still on straight MCB... as was common when the house was built 20 years ago. Circuits are downstairs sockets, kitchen sockets and upstairs...
Hottub is plugged into an outside socket, which is spurred off a downstairs socket, via a switched fuse, and has its own 10A RCD on the flex. Its on a low load circuit.... not the kitchen. So TV, laptops, wifi router, a few lamps.... i could clamp the circuit cable to see what exactly was being drawn.
But, the hottub is going straight for the 32A breaker... not the 13A fuse in the sw/f. And only intermitantly.... might hold for half an hour or more, then go off again. It has been fins since i unplugged the hottub.
I am thinking its one of the water pumps, and i have not drained the tub for that reason... so i can test it with water in. really, it is just pumps, valves and a heater.
Is there an easy to follow sequence of testing these things that anyone can recommend? I dont want to just start replacing perfectly good parts for no reason.
