Moley
Supporter
I'm still ongoing with the rewiring of my daughters house. Yup, going on for 2 years but not my fault. Been waiting for them to do so many other jobs such as putting floors and walls in, new roof etc. I'm hoping they will be at a stage for me to finish first fix upstairs soon. Anyway, I'm getting to the point where I want to plan installing smoke alarms. I was planning on wireing them in to the lighting circuit and interlinking them but, if upstairs are on one light circuit and downstairs are on another light circuit how do you interlink them?
you either extend the last downstairs detector up to feed the one upstairs, and not use the upstairs lighting circuit.... or, install a radio module in one on each circuit... so the 2 wired systems talk to each other
Being a tight git I think extending the downstairs circuit to include the upstairs alarms would be best. Still got time to run the cables before last bit of plasterboard goes in. Luckily I'm on call next week so should have time.
Its just a 3 core and earth from the first one to the second. All on the same circuit. Easy when your doing a rewire as you're making mess everywhere and can usually fairy easily find a route up to the loft from the ground floor.
you can branch off the 3 core anywhere from the downstairs circuit for ease of routing...
or, in theory, you could just send a single core for the signal wire, and take the L and N from upstairs circuit... but that seems like an overcomplication
A couple more questions as I've never fitted smoke alarms before.
How do you know where to mount them? Ok, I know they screw to the ceiling but is there a best area of the ceiling?
I'm thinking one in the main room downstairs (big room, originally 2 rooms now one), top of the stairs and one in each of the three bedrooms. Does that sound right?
I'm looking at Aico Ei146e. They are £30.99 at Screwfix. Being a tight git is anywhere cheaper?
And now the big question, why am I wide awake at 4am?
I think england and wales are the same as Scotland now, so the guidelines are
1 smoke on each floor, escape routes… so hallway and landing
A heat detector in kitchen
A smoke detector in main living room
A smoke or heat in any other high risk areas… adjoined garage, attic, cellar…..
The aico website has downloadable documents for locations on the ceiling… not too close to walls or light fittings, windows and doors… not too far away from sources of fire.
No point outing a heat detector 20’ away from the oven etc
Don’t be stingy. Go for the aico 3000 series.
And don’t forget carbon monoxide detectors! Boilers, stoves, open fires…
