Is it just me?
Is it just me?
I have finally had enough of screw heads failing when being tightened to the manufacturer's designated torque.
I know perfectly well (being doing it very successfully for decades) how to deploy a screwdriver in order to maximise the chances of not munging the head of a screw but I am thoroughly sick and tired of how easy it is for the head of screws in consumer units to be damaged before they reach their designated tightness.
Just a random howl into the wind. Thanks for listening.
maybe your torque screwdriver needs calibrated?
No one, however experienced, can tighten by hand and say, "yep. that's 2.4N/m... no more, no less"
Experience will tell you when its really tight (the plastic splits open) but that little bit less tight could still be too tight ... or too loose.
They wouldnt state a torque if it didnt matter
I think you may have slightly the wrong end of the stick.
I am most definitely not complaining about the need to torque screws correctly.
Nor am I claiming to have a 'calibrated arm' and therefore don't need to deploy any of these new fangled torque gadgets.
I am very much onboard with correctly torquing screws and always have been.
I am talking about recent experiences with a brand new Wiha torque driver setup - including all new bits in excellent condition but my actual annoyance far predates this recent new acquisition.
I've been getting the same end results with my Armeg torque screwdriver for as long as I can remember as well.
I know it is not my technique because I am fanatical about driving screws correctly in all contexts and regularly bore to death on the subject to anybody that is unwise enough to stand too close for too long.
So, to be slightly more serious for a moment then, I am genuinely interested to hear from others on this subject. If you don't end up munging a percentage of the heads on your screws I am keen to try and figure out just what it is that I am somehow inadvertently doing wrong. My 'kill' rate varies but in a typical 10+ module CU I rarely manage to avoid buggering at least one screw head - and you only get one shot, once that driver slips that's it for that screw in terms of correctly torquing it up.
apologies... i had just had a real world conversation with another electrician on that particular matter. I use a torque driver... he does not..... waste of money, etc etc
I too have a Wiha torque driver... it came with a size 1 and size 2 +/- bits .... so a cross head and straight in the same bit. The size 1 lasted about 5 minutes on the smaller terminals of an RCBO.... The size 2 was a tight fit into the plastic covering, so i just had to use it.....
The size 1 got replaced by Wiha FOC as i said it should have lasted longer than that.
The Wiha also uses a different size hex shank on their bits than other manufacturers...
I know what you mean about the terminal screws though. either they are soft metal, or they are too big to accept the standard size 2 bits.
I know what you mean about the terminal screws though. either they are soft metal, or they are too big to accept the standard size 2 bbits.
I've long held that most industries have been moving from proper metal to some form of soft cheese alloy. Everyone wants stuff cheaper, and we've (collectively, despite the cries in the wilderness warning of it) to fall for for the allure of "send all your work to us, we'll do it properly, using good materials, and definitely no child/slave labour" messaging from China.
Anyone who's dealt with China on moderate scale business level knows you have to have really good quality control at your end - random sampling, full destructive tests, and so on - to make sure that what you are selling as meeting UK standards actually does, you can't trust that the production units will match the samples supplied for your original assessment.
