jelly crimps
I don't use them, but discovered if you paste your question verbatim into Google, and select 'AI mode', you get a comprehensive selection of answers 🤪!
Well that's what I thought @Avo Mk8 , and I was looking forward to replying to this post with an equally clever answer.
However, I can't find any!! :D The smallest is for 0.4mm diameter wire.
I think you were right though...
That is, assuming we choose to believe AI
Railwayscenics, which comes up in the AI list, seem to think theirs will do 7/0.2
Not sure about IDC for stranded, but many people claim it works!
Only way is to try the 0.4 mm and see if it gives continuity. Cheers for the heads up guys.
I'm sure you will get connectivity, but it's more a question of long term reliability.
If it's being used in a fixed installation, indoors or out, it should be fine.
If it's bouncing around in a vehicle, or on a flex being moved, there's a small chance of an intermittent connection after a lot of use. 🤔
