I was doing a job today, moving a few sockets in a domestic kitchen. Whilst doing my tests, I had the cover off the MEM Memera 2000. I checked the tightness of all the connections, and found that the screw for the 25mm 6181y live incomer to the isolator didn't appear to tighten.
There was no sign of thermal damage to the cable or the terminal, the cable appeared tight in the isolator (although that might be because of the way the cable has been bent into the terminal). Quite possible that the terminal had been over tightened on the original install, and the screw head snapped off, but no way to be sure, without taking things apart.
Anyhow's, I've informed the customer. So far as I'm concerned, it's a new isolator. Seen loads of these CU's installed, and plenty of used MEM ASN100 available on ebay, but I'm not really happy with installing used switch disconnectors etc.
Eaton UK tell me there's a compatible isolator - SPC MS 1001N - available, but can't find it on the wonder web.
Anybody, had same issue, and got this compatible isolator?
