B
Blaspark
From what I see it just does redundancy with a loop. It's like profibus.
You have snmp though so not so bad
You have redundancy available by creating a loop. Obviously I don't know how to set it up since I'm not familiar with you tech and it might only be available with certain hardware. It's available with cc link thoughNo redundancy features such as slave CPUs etc. Reliability has not been an issue.
They are of course all on a UPS power supply system.
I agree although triacs can handle the higher loads in some system its highly recommended to use fuses or overcurrent devices between the output and coil.Only with S7-400 CPUs can you have redundancy with Siemens so far, they are still working on the S7-1500 to have that functionality.
You can have a profibus network wired in a ring with a suitable ring manager, but this is not the same as redundancy.
Redundant CPUs is not overly complicated to set up, but the cost is huge for the hardware. An then it is only the CPU that has redundancy. In my experience, as long as they are installed in a decent environment, these hardly ever fail. It's usually the IO.
Just noticed a mistake in my post above, I should have said profinet, not profibus.
Profibus can be made into a ring topology, but needs a fiber optics with converters as a backbone, an to be quite honest I have never seen it done.
Profinet is Ethernet based, where as Profibus is a form of RS485 communication.
Have a try, you will know it
hello? I can't understand, who is a robot?After seeing several nonsense postings from yourself. I'm fairly certain this "user" is an AI bot.
The golden rule is to stick with the current brand of PLC used in industrial facilities. [Standardize] Plant maintenance (the true end-user) will already be familiar with it and may already have software for that brand, etc. Why? To reduce the customer's downtime, which usually costs the company way more than purchasing and installing a new brand of PLC.Allen Bradley unit in the old system
