Wonder if they do one for granite walls in cottages - race against the experience spark then MR Inventer!
Here 'tis ...
I do like these time saving devices, save 10 seconds here, save 7 seconds there and then then they go and sit in the toilet for 25 minutes.
Now I only take about 30 seconds on the toilet, 30 more for washing my hands (properly) so Ive save 24 minutes - I can then take my time with my padsaw and my measuring and levelling! AND I'VE SAVED £200
only 30 seconds on the bog??? my first fart last longer than that.
You need to share the knowledge Pete. It was two of your (least) favourite new phrases all rolled into one!
No offence - Thursday night stupid moment.
Absolutely pointless.
If you can't cut a box square and level you need more practice.
If you need to save a matter of seconds you must be doing a lot of plasterboard cuts.
If you are doing lots it must be a large new install.
If it's a large new install you should have persuaded the joiner to cut you a load of noggins to mount metal boxes on sat 5mm proud of the stud so the boarder has to cut your boxes in for you.
Leesparkykent,
onions1066,
