U
underpar12
hi can anyone explain why you need a polyphase meter in a domestic property.i am doing a new build 1st fix and a little confused.
I am finishing a house at the moment where there is a need for 3phase
Once the swimming pool pumps are added we are looking at around a 40 amp per phase loading (no exact calcs ready as client still keeps adding or changing light fitting etc)
Even with diversity the house is over 100amps
Note, it is the size of 10 2 bedroom modern homes (the foot print of my 2 bed house would sit in the master bedroom alone and that 1 bedroom has 24 lights in)
There is a 30 amp pump just to feed the tank to feed the 3 x 300 ltr cylinders which feed the 6 bathrooms
no thanks :D
I am over 50 miles from you and i estimate only 3 days left to connect and test the consumer units ( swimming pool not done to till next year)
And at your £5500 for a 3 Bed 1st fix your are to expensive for the clients around this end of the woods (they are tight) :)
Any supply with more than one phase is polyphase. Split phase, 120° two phase, 90° two phase. 3-phase, 6-phase up to 48-phase.
