N
Notsosmart
Thought I had better post this in here as the language may get colourful
The Potholes (make that canyons
) around my way are getting rediculous the council appear oblivious and it will only be a matter of time before I end up with damaged wheels &/or tyres, worse still a motorcyclist ends up hurt.
The amount of roads and the amount of holes in those roads must mean that they haven't been maintained properly for years, you can see that the last time one was covered the barest minimum covering of asphelt was used. The bloody service companies have a lot to answer as well; a lot of filled digs have sunk or disappeared altogether
So we've had a bad winter, boo hoo, how the hell do they cope where it gets really cold and use snow chains then.
I feel better for that rant.
) around my way are getting rediculous the council appear oblivious and it will only be a matter of time before I end up with damaged wheels &/or tyres, worse still a motorcyclist ends up hurt.The amount of roads and the amount of holes in those roads must mean that they haven't been maintained properly for years, you can see that the last time one was covered the barest minimum covering of asphelt was used. The bloody service companies have a lot to answer as well; a lot of filled digs have sunk or disappeared altogether
im going to make all my posts in the sparky pub..!!
who is certifying them and issueing the contracts; surely the fact that they were lacking the necessary equipment to successfully undertake the task should have rung alarm bells with an inspector ~ I guess enough paper printed with the queens head one side & sir John Houblon on the other will muffle any cries of despair
