Discuss pulse coil 2000 in the Australia area at ElectriciansForums.net
deller
Hi to everyone. I am new to this site and look forward to becoming part of this community!
I have a job to take a look at in the next week. Its a 'pulse coil 2000 combi' which heats running water, but then becomes cold very quikly apparently. A plumber has changed the element and has been back to the property with no luck. The tenants complain that the water turns cold after only a few moments in the shower?
Any ideas on what could be causing this problem?
Many thanks
Pulse coil 2000:eek::eek: Isn't that connected to the warp drive on the Enterprise???
Seriously though.
Maybe some form of flow or pressure switch to sense the water flowing which is turning element off...
Reply to pulse coil 2000 in the Australia area at ElectriciansForums.net
Hi, We are renting and have a electric shower downstairs (extension) - a 9.5kW Triton T80Z fast-fit electric shower as well as a combi boiler...
4K
Bit of a strange one ive been told by everyone ive called had a triton t70xr 8.5kw The water started running cold like the tco kicked in after a...
Hi Absolutely 0 knowledge of this so excuse language / terms / explanation. Electric only ground floor 2 bed flat ( 3 external walls) On peak...
5K
HI Folks. This is my first post so apologies if it's in the wrong location. I recently installed a 3kw Solar system with an iboost diverter...
5K
