Discuss rho value in the Australia area at ElectriciansForums.net
P
philaxgt500
i'm in year 3 and i'm stuck on a year 1 question, is there any hope for me??
i was wondering if someone could jog my memory on this 301 question please.
question:
A copper conductor has a rho value of 17.5 x 10-9. calculate the resistance of the copper wire if it's length is 20 meters and it's CSA is 2.5mm2
cheers phil
Hi Phil.
Ok so resistance (R) = (Rho x l)/s where l = length and s = CSA.
Are you sure you've got your units right?? as the resistivity of copper is 1.72x10-8 and they usually give the diameter of the wire not the CSA. So you would also need to work out the CSA = pie x r squared
Or is this a hypothetical question??
Let me know.
Cheers:)
resistance r = pl / a (ohms) p (the greek letter rho) is the resistiivity value for the material l is the length and a is the cross sectional area got the book next to me lol
its been 9 years since I was in college and I aint got no books by me either. The old grey cells aint what they were:(.
I think I was right thought just with different letters. R= Rho (P) x length (L) / CSA (S).
Where L = length and S = CSA. Your book says CSA = A though.
Makes the same sum, thought doesn't it????:confused:
I don't remember any of this, Cheers for the help.
And now for your next question,
A conductor 600mm long carries a current of 300 milli amps and is at 90 degrees to a magnectic field with density or 1.5T. determine the force exerted on the conductor.
erm dunno lol
Trust me.;)
F=BIL but as your current is at 90 degrees to the field then the formula is F = BIL cosine theta. As the angle is 90 degrees then cosine theta = 1.
Where B = flux density, I = current, and L = length.
So - 1.5 x 0.003 x 600 = 2.7N.
I think. It's been a while since I did this stuff and my swede is aching a bit now.:)
Lenny, take it N= Newtons, eh still remember that bit, ofcourse thats if i am right mate.
Spot on Sir.
It's been a while for me too. The old grey matter is taking a bit of a bashing but it still seems to be working though.:)
Thanks alot everyone. i should hopefully be able to do the next 50 questions, But if i do get stuck i know where to come :D unless of course you want me to scan the page and put it up so you all can have a go at the 52 questions?? ;)
Reply to rho value in the Australia area at ElectriciansForums.net
Hello all, I wonder if I can get some opinion on my deliberations on an old TPN installation with numerous 1P sub-boards wired up with 16mm T&E...
Hi all I have a professional coffe machine working at 220 V and it currently drain about 2,5 kW of power. I have made this simple and horrible...
Hi everyone, I'm new here and was wondering if someone could help to get my college project calculations right. I'm about to start my 2nd year in...
7K
Over the last few days, I have stumbled across a number of threads that seem to point to a prevalent misunderstanding. Either that, or I have been...
Those week I have mostly been fitting 20 x 10W flood lights on the sloping edge of a converted mill ceiling, nothing is straight, nothing level...
