Hello. I am not an electrician. I do have good knowledge of electricity however. I am running a spray booth with a 10 hp motor. I am also running a rotary phase converter. The motor burned up and I had it rewound. An electrician friend told me it is possible that the capacitors in the rotary phase converter went bad. I had them checked and they said they were bad. The replacement capacitors are no longer available. They are dual capacitors. I am going to have to get separate capacitors and wire them in. The schematic is missing and I am trying to identify which leg the 90uf capacitor goes to and which leg the 5uf capacitor goes to. Does anyone have any info.
