O
Olliew
Hi guys
I am going to be inspected next week and have been told napit have been failing installations because countersunk screws in back boxes. Should I change all screws too round head as it is all finished and a lot of work .
That is a joke if you ask me to be honest. Use the easiet fastener for the job for ex: domestic into red plugs countersunk all the way, roundheads should be non existent. Hope this helps derek. I'd never order roundheads for any of mine or my lads jobs. Derek
I assume one size fixes all for you as well
Roundheads within trunking and conduit boxes everytime. As for accessory boxes I have no problem with countersunk.
A piece of gaffer tape over them should keep the inspector happy, as the tiny edge of the countersunk is then covered.
Must admit, I did use round head pozi screws for a while last year, as I had seen some cables that had been shoehorned into back boxes with their insulation nicked. I don't anymore though as I had run out LOL
If you want to though, why not use then from now on, then next your Mr NAPIT won't pull you it.
The one bonus of round head is that if you've drilled your fixing holes off slightly, you have adjustment on the screw, where as a countersunk is tightened it will always pull whatever you're fixing into line with the center of the screw.
Alos one other thing. If you are fastening trunking to a wall using screws, what type would you use then?
