Discuss some help!!!!!!!!!! in the Australia area at ElectriciansForums.net
U
Unregistered
hello im new to the trade in currently doing the city and guilds 2330 and i also did a peo nvq level 1 last year but i was wondering if some1 could help me i just want to no the basics and some help on my course.
i also would like to no what happens or wt does it mean when there is no earth in a switch. thanks.
"i also would like to no what happens or wt does it mean when there is no earth in a switch"
Wat switch? Light switch? Sitched FCU? Is it metal or plastic?
Well dont be shy, post any questions you are unsure about I'm sure somebody will be able to help & advise:).
No earth at a switch? (lighting I assume)
The earth may be supplied via metal conduit hence no visible earth cable or the installation is 1960(i think) era with no earth on lighting circuits.
In the event of no cpc you could always install one for the circuit or re-wire the circuit in T/E.
Or change all fittings to class 2 fittings, replace all metal plate screws for nylon type note at cu " no class 1 items to be used on lighting circuit" :D
ok thanks yer i meant a light switch what does the earth actually do then?
wt would happen if there werent an earth in a switch?
The earth does what it say's on the can, it is the circuit protective conductor (cpc).
At a light switch you may find a single conductor (T/E switch drop) terminated to the metal back box, so giving a fault path from the plate screws - back box - cpc - back to cu - on to suppliers earth.
Or
The switch back box may be used as a JB so you will have all cpc's terminated into one terminal block .
Hope that sort of makes sense :confused:
it's a sub forum for members who have over 3000 posts.
Reply to some help!!!!!!!!!! in the Australia area at ElectriciansForums.net
Hello and thank you for accepting me. My name is Ioan and registered for some tips and help when I'm gonna start city e guilds lvl 3 and the...
having enrolled myself onto an electricians course at the end of jan, after deciding on a complete career change of baker/retail worker in the 25...
Hello to anyone reading this . I am from the HVAC trade been working with 3 phase and controls for the last 20 years . Started my electrical...
Hi My name is Bryn and I live in St Albans I have currently done the level 1 domestic course the level 2 city and guilds 2365, the city and...
Hi everyone, I'm currently working towards getting qualified as an electrician and am hoping to get my foot in the door with an apprenticeship or...
