Hi folks, I was resiteing a shaver point in the bathroom of a 1970/80 house in Bristol this week. I was a little surprised to find the stud wall packed with straw as the insulation!
Does anyone know of the best way to fix metal back box to straw?
I've used a dry wall box this time but just in case I get caught without one next time....
Thanks in advance.
Same way you'd try to fix it to fibreglass or mineral wool I suppose - fast fix box or noggin.
Havent seen this in about 10 years now, most places have been pulled down and rebuilt. But i can rember having a nightmare trying to keep backboxes secure.. good thing modern fixings are avalible.. I used to use 2-3 inch screws screwed out the side of the box into the wall.. if the box pulls out so does half the wall :)
not as bad as some council houses with internal walls made of 2" thick breeze block. chip in for a back box and the customer ends up with 2 sockets back to back for the price of 1.
Came across similar a few weeks back, what a horrible job, had to chase around 4 sockets within this stuff, used a stanley knife and it took a lot longer than chasing brick
The straw is quite tightly packed, i used a few red rawlplugs, seemed to hold pretty well, also fixed the boxes by driving long screws in top and bottom of the boxs
My own house has all internal straw partition walls, upstairs and down, built in the late 80's.
I have added many socket and switch boxes over the last 25years.
I follow the method used by the original installer;
Cut recess for box using stanley knife and holesaws.
Remove half a dustbin of compressed straw for each twin s/o box fitted.
Using metal back boxes, drill 2 x 5mm holes in each side (4 in total) close to the back corner.
Fit box flush with plaster.
Push in 4 x 4" nails sideways thro holes into straw.
The boxes never move and can easily be removed in the future.
If there isnt too many you want to think about changing them, in the event of a fire your house wouldnt stand a chance with all that straw
I was working years and years ago and found straw walls went to boss to ask and got told get everything out and leave well alone, when I asked was it a fire risk he said no cos they used a asbestos coating on it to stop fire and that we would have to wait to have the wall removed, which took ages, did think at the time it cant be can it
