Discuss Tap and Die in the Electricians Chat - Off Topic Chat area at ElectriciansForums.net
diditrain
Hi all, is anyone familiar with re-tapping?
I need to replace a bolt on my multi fuel stove as the old one snapped.
Is there a general rule of thumb?
e.g. if i wanted to use a 3.5mm bolt what size drill bit would i use and then what size tap would i use?
Many thanks for any responses
If you havent a clue, get a tap you think will be about right, and a bolt to match it. Get your box of drills out, and offer up the shank of a few to the thread on your bolt. By eye pick a drill that appears to be the same size as the bolt without its threads.
Drill yer 'ole, tap yer 'ole and fit yer bolt......doddle
Obviously you could refer to standard thread sizes and screw pitch and match it up dead right......but if its a non-crirical assembly I would just use "by eye" if I were you.
Hope this halps
Randyrat
Reply to Tap and Die in the Electricians Chat - Off Topic Chat area at ElectriciansForums.net
hi. would appreciate advice from any electricians. am trying to replace a 13amp [35 year old MK] wall socket but the terminal cage in all the...
Hi All, Looking for a bit of advice. Just bought a boiling water tap, with a max kw rating of 1.5. We already have a waste disposal under the...
Hi, I recently had an EICR done at my property which unfortunately was unsatisfactory. So the electrican advised a new fuseboard from BG General...
Extremely low voltage on 120v line Hi, I’m not an electrician but my home has 20 amp breaker that has only one outdoor outlet on it with a GFCI...
I'm installing smart modules in my light switches which means I need to replace the existing 25mm back boxes with 47mm ones. Downstairs all walls...
