Guest viewing limit reached
I have problems when testing a Nch MOS-FET. I have learned how to do it on YouTube. However after I have touched the gate with the red pin the MOS FET does not close and I get no readings between the drain and the source.
The gate threshold voltage (Vth) on this particular MOS FET ls Min 3V and Max 4.5V. I have a FLUKE 75 Multimeter.
Can it be that the voltage on the pins are to low to close the MOS FET? And what voltage is it on the pins?
When I think about it, this is maybe not the right forum to ask electronics questions?
Can it be that the voltage on the pins are to low to open the MOS FET? And what voltage is it on the pins?
Have you measured the mosfet ? can you measure the a parasitic diode ?
You may need to drive the gate with more voltage, especially if it's a fake one.
O
The Fluke 75 uses a constant current source when measuring resistance, which seems to typically provide just microamps.
A random Google suggests the max voltage on meter pins doing resistance measurements is 3V, so it may not be enough to switch the mosfet.
A copy of original ones, usually Chinese copies.
Take a look at these, do you have a power supply.
View: https://www.youtube.com/watch?v=XXcEgddzjnI
View: https://www.youtube.com/watch?v=ElTTOsj3y-Q
Oh my Gosh! I bought them from AliExpress - China so I guess they are fake then? But they don't look like in your linked video. I attach a picture so you can see. The left one is supposed to be a STP4NK60Z and the right one a 2SK3868. No I haven't a power supply so I can't measure them.
If they were very cheap then i doubt they are genuine, but should work just to a much lesser degree than an original one.
Sweden
All Other Countries (This Is English Speaking Website Only - WE don't mind Google Translate Users :)
Testing MOS-FET with Multimeter.
DIY Electrical Advice
Thread Tags
Tags Tags
testing
Krister Persson,
mainline,
