Hi, I have a job coming up in which I need to cut a new cable entry for a 25mm armoured gland in an existing consumer unit. There's plenty of space for it in an existing 3 phase protek board. But it's awkwardly situated and no precut knockouts available. Just wondering if any of you have any recommendations for the best tool for the job?
Can you get a smaller hole in there then use one of
THESE
but obviously the right size
A hole saw would be the obvious choice unless there is a reason you can’t use one.
Agree with above - just use a hole saw. Q-max (or equivalent) cutters are a bit extravagant unless you're going to have a repeat use for them - and you still need to drill a hole.
If space is tight, a right-angle adapter for the drill.
I'm a Q-Max fan. Yes, you do need to drill a pilot hole but that is far less graunchy than a hole saw and less likely to do damage to the CU if it is populated.
That's a fair point. However, if used just a few times, and saving so much time and effort...well. add £3 to the bill and they are paid for in no time, and you will never need to buy them again...but hole saws? Worn out, juddery, innacurate, messy...
Just my view, obviously.
I showed an electrician my Q-Max 20mm when he was struggling to find a way to make an entry into a populated board...he was a fully qualified guy in his 40s, and had never seen them before. 2 weeks later he was back on site and proudly showed me the full set he had bought, and told me his work-mates had also never seen them before.
It's the same with Quinetic switches and Wagos...full time sparks who had never seen these innovations...
Oh well, time will tell...
I nearly got kicked off this site years ago for promoting Quinetic stuff!
Step bits leave a clean edge, much cleaner than a hole saw, and generally cheaper than a hole punch set. I love hole punches, but as stated, the price! Depends on how many you do.
