Discuss transformers in the Australia area at ElectriciansForums.net
Z
Zaffy
Please can anyone explain the theory behind transformers and 12 volt halogen bulbs.
My dimmer transformer is about ten years old and is made by IBL lighting.
It is a 4105.00, this is presumably their number.
20-75VA 24 230AC 50/60HZ 75VA max
Six 12volt halogen bulbs run off it. What wattage is allowed.
Thanks.
You don't say what the wattage is on these 6 12V halo's
I wouldn't go more than 50/60 total watts max!!
That transformer is getting a bit long in the tooth now at 10 years old. Think about replacing it, with a suitably sized unit for your needs...
Dear Enginner 54,
Do you mean 50/60 watts max each bulb? That would mean just 10 watts per bulb.
or
the total of all six bulbs equalling 50/60watts max? That would work out to 360 watts max.
The lights are not working and I wondered if I had overloaded the transformer.
I was thinking of buying an exact transformer replacement, the model is still made by IBL Lighting.
well, 1 halogen lamp is usually 35VA or 50VA, so looks like a definite overloading . personally i would use 1 transformer ( 60VA) per lamp.
Dear Enginner 54,
or
Ever so slighty
Dear Enginner 54,
or
Wow, ....And there was i thinking that you had one of these set's, with those 10 or 15W push in Halo lamps. ...lol!!! Just how long did this transformer last, with trying to drive 360W ....not long i shouldn't think!! As others here have suggested, use a single transformer with each lamp, or go with 230V halogens, they tend to be a more reliable set-up in the long run anyway...
Reply to transformers in the Australia area at ElectriciansForums.net
I have halogen lights in my kitchen under the wall units, there are ten lights altogether bulbs are either 10 watt or 20 watt G4 bulbs ( not sure...
Hi all, Im new to the forum and wanted to check something and maybe get some advice confirmation. Ive got halogen wall lights which use a...
Hello, this is my first post here. I have a little experience with most types of household wiring through a decade of DIY remodeling, and...
Hello, I was hoping to get an idea of what's wrong with my light before paying for someone to come out and tell me that I just need to buy a...
J
One of my customers have asked me if they can recommend a dimmer that will work with "E27 T5 Quick start 11W CFL -460Lm". Below is an email...
J
