I have a Vaillant ecoFit pure 830 which developed the f.22 fault, the pressure had dropped to 0.2 bar, i refilled the system and away it went, i noticed yesterday that there was water on the floor below the boiler and noticed that water was leaking from a small hole located behind the condensation trap. This leak is lowering the pressure but i don't know and can't find anything on what is causing it.
Does anyone know what might be causing the issue and how might it be fixed?
Thanks in advance
Continue reading...
Vaillant EcoFIT pure leaking water from behind condensation trap
Plumbers Forums
Thread Tags
Tags Tags
None
markswan20,
