Hello everyone
I've been asked to quote on a job.
Install energy saving light controls in 90 serviced offices.
The offices are quite small in size and l've sourced some 'no neutral' PIR timer controls which can be retro fitted into the existing switches.
This will do the job fine as well as a cheap and quick install.
I'm doing a site visit to check all is well.
My concern is:
The company who wants the quote requires that l state 'make and model' of all equipment that l would supply.
Nothing stopping them once l give them that info to buy it themselves etc.
I fell a tad vulnerable.
Anyone got any advise?
Cheers
Tom
only time I ever seen "make a model" was for a Network Rail office building that was a new build, and that was a few million just for the lighting contract.....
if the offices are in close groups i.e in just a few buildings......I would go for a DALI lighting set-up.....if they are looking for cheapius maximus for something like a lighting control set up, I would walk away as you will spend just as much time going round fitting them and finding other problems which they will expect you to fix for free in the end..
I would imagine that they are looking for some kind of smart system and that if you were to fit independent PIR units they would start to complain about lights going out when people are sat at desks......there are some PIR units available which can be set up using a keyring remote control, is that the ones you have sourced?
you could get whitecroft lighting or similar to send a rep with you who will take a DALI box (only need 1 control unit) and a DALI connected light fitting and they will plug it into a laptop and let the customer play around with the settings to see it working......no outlay for you and the supplier/manufacturer don't install so theres no risk of losing business to somebody else....will also make you look good having a rep visit....and you can get info on other lights etc...
@tom, I think they're just concerned with material/equipment quality. It's not uncommon for some firms to quote a price then stick in cheap as chips low quality gear to maximise their profits. Get half decent mid range and add your mark up/ labour after that. These guys sound like they know about being short changed.
Sorry if l have not explained myself.
They want to control each serviced office independently of each other. The folks who rent these offices often leave the lights on over night. They just want a sensor and timer/lux level control.
It's a case of:
I've found you a cheap way of solving your problem and you want me to tell you how to do it and l hope you will then pay me for it.
How much time and effort = money
do you put into getting your work?
Can't do much more than that.... as its such an easy thing to fit they could get the maintenance guy to do it.
I just dont want to waste my time.
Thanks for your reply
Tom
I hear you, sourcing stuff. Web search and email job. No links to suppliers. No exact locations of pirs. Maintenance staff usually can't sign off. Business' require it for their insurance.
Tom have a look at Procom Lighting Services and give the guy a ring he's called Lawrence he will advise you. I do all his install works for him but he will supply only and the product is superb.
You could be right about more trouble than its worth, l have mentioned the PIR issues to them... the units l am going to spec are by CP electronics. THanks for your reply
Tom
when push comes to shove, you're not getting the job if you don't play by their rules. if it was me, i'd go for it and hope for the best. 90 offices sounds like a nice earner.
A thought.....
If they went down the line with....
Exchange existing switch to a PIR switch.
The PIR can be retro fitted.
Would they need to sign off as they are only changing one switch for another... I know its not 'like for like" but its still another type of switch... no neutral required.
A Danlers rated at 20 amps would be a good bet, a lesser detector may not cope with the load, even a couple of fluorescents starting up will put a cheap Absence Detector under duress IMO.
Tom, you dont need to tell them that, just word estimate appropriately to include 'all certification/signing off etc in compliance with...'
