Discuss Pyro in the UK Electrical Forum area at ElectriciansForums.net
It's flippin great stuff and as has been said earlier will outlive it's installer many times over if done right.
I find a lot of people are frightened of it but there's really no need to be (as long as you have some decent experience of it I suppose) It's modern equivalent (FP) is utterly useless by comparison.
Ahh...sums it up pretty well..nothing to touch pyro in the right situation. I only wish I'd have had my mobile in the 70's and 80's to take a few pics of boiler houses done in the stuff. Drilling 20 or 30 3/4 holes in in the top of a control panel, making and shaping and then standing back admiring the symmetry of it all....and nobody else interested. Then touring a burned out working mens club in South Yorkshire...everything black and charred with even the steel framework twisted and distorted and what was left, strung up between the uprights, laughing down on all the rubble...we all know. Oh for me i phone!!!
Morning guys, bit of nostalgia for you vets.
Wiring up an MOT bay, went to see the excavation so we can draw up the plan, they pulled some pyro out that was buried 1.5m deep, and was amongst a news paper that had a 1970's date on it.
Gave it a whirl on the tester for banter, still returning <199 Ohms on insulation test between live conductors!
Been battered by the jcb as well.
Use “charmap” on your PC and you could write the reading correctly as >199MΩ
What are you going to replace this “pyro” with bearing in mind it’s a garage pit and falls outside the scope of BS7671 regulations?
Swa by the looks of it, is that blasphemous? Turns out we only have to supply 3 phase to lockable rotary isolators, and then the technicians take over.
I can't believe people just painted straight over all of it where I am, same with the massive copper earth bars all over the place...
When we were taught mi in college we got to beast ot with a rubber hammer and totally flatten it and then test. Good fun, even better when one of thE lads hadn't made the end of correctly..... BANG. On our AM2 the instructor used to put ear defenders in prior to energising the install lol.
Going to get grief over this, what happened to learning to work with MICC on the job?
I would compare it to doing your driving test. They teach you how to use the tools and make one off at college. But you learn how to do it properly and efficiently on the job! I did a day of making up about 25 4m lengths of pyro and glanding both ends. The tools at college were abit pap and they didn't have any vaseline...
Vaseline????????
Vaseline baby!
This is where you all lay in to me now!
When using the sheath stripping tool i was shown to put a dab of vaseline on to get it started! Possibly only necessary if the tool is getting blunt however it definitely seemed to help!
Vaseline baby!
I'm really sorry Mate the essence of making off MICC is to keep it dry, clean of any grease and that include Vaseline, someone sold you a pup Mate.
1961 it was my first day at work guess what a pyro job, polishing it as it went into a fuse board, non PVC covered in those days, the sparky in charge stripping pyro like there was no tomorrow, and not a tub of Vaseline insight,
I appreciate that's what you have been told, but nothing beats a well sharp and well set up stripping tool "keep it dry and clean" it stuck with me all through my working life, Vaseline indeed.
Bet he went through blades at the same rate he smoked...
The potting compound itself is oil based, hence the low insulation reading on first fix.
Vaseline and oil, are both messy and again don`t help readings. But will save the blade.
Best method I`ve seen and use, is candle wax. Just a plain old candle rubbed over the cutting area, no mess, helps cutting reserves blade.
I've got some pyros to do in a few weeks time I'm going to try that and see if I can make my last few blades last
Reply to Pyro in the UK Electrical Forum area at ElectriciansForums.net
