Currently reading:
Pyro
Discuss Pyro in the UK Electrical Forum area at ElectriciansForums.net
S
sammyshooter
Morning guys, bit of nostalgia for you vets.
Wiring up an MOT bay, went to see the excavation so we can draw up the plan, they pulled some pyro out that was buried 1.5m deep, and was amongst a news paper that had a 1970's date on it.
Gave it a whirl on the tester for banter, still returning <199 Ohms on insulation test between live conductors!
Been battered by the jcb as well.
Going to get grief over this, what happened to learning to work with MICC on the job?
I would compare it to doing your driving test. They teach you how to use the tools and make one off at college. But you learn how to do it properly and efficiently on the job! I did a day of making up about 25 4m lengths of pyro and glanding both ends. The tools at college were abit pap and they didn't have any vaseline...
Vaseline????????
Vaseline baby!
This is where you all lay in to me now!
When using the sheath stripping tool i was shown to put a dab of vaseline on to get it started! Possibly only necessary if the tool is getting blunt however it definitely seemed to help!
Vaseline baby!
I'm really sorry Mate the essence of making off MICC is to keep it dry, clean of any grease and that include Vaseline, someone sold you a pup Mate.
1961 it was my first day at work guess what a pyro job, polishing it as it went into a fuse board, non PVC covered in those days, the sparky in charge stripping pyro like there was no tomorrow, and not a tub of Vaseline insight,
I appreciate that's what you have been told, but nothing beats a well sharp and well set up stripping tool "keep it dry and clean" it stuck with me all through my working life, Vaseline indeed.
Bet he went through blades at the same rate he smoked...
The potting compound itself is oil based, hence the low insulation reading on first fix.
Vaseline and oil, are both messy and again don`t help readings. But will save the blade.
Best method I`ve seen and use, is candle wax. Just a plain old candle rubbed over the cutting area, no mess, helps cutting reserves blade.
I've got some pyros to do in a few weeks time I'm going to try that and see if I can make my last few blades last
....Why have BICC provided a small tub of vaselin with a pack of 10 terms for the last 30 years. I've not always used it but when I have, a tiny bit on starting the strip hasn't made the slightest bit of difference to the integrity of the stuff....might do if your stripping an inch but I doubt it.
I always thought the tub of lubricant that came in the packet of ends was to help ease the pot on to stop the cable twisting. How many times you heard the screeching noise where someone is forcing the pot on.
You install and dress it properly, you shouldn't need anything lubricant to strip it with a stripping tool, I use a big screw driver on the bigger gear, using a ringer to get the clean edge.
Smaller gear with a stripper, then ring it off against a pair pliers with the stripper.
A bit screwed rod with a slot in it was good for the bigger stuff.
i found a wipe down with an old bit compound aided stripping with a joistripper.
on the subject of Vaseline I got tasked with sorting out the batteries for central battery em light system.
sorted out the cells and went down to boots with my fresh faced first year laddie
asked for the biggest tub of Vaseline they had to funny looks from the boots ladies......
Glad to hear your pulling out dodgy cables, sell it for scrap!
What and put some of that even dodgier FP rubbish in it place
Don't think any of the old hands here will be in the slightest bit surprised by that finding. A MICC cable installation installed by competent electricians will out live the installer and his children, even if taking a few bashes over the years, so long as those bashes don't penetrate the sheath.
Probably the best general small to medium multi core cable size system ever produced
Might even out live the installers gran kids
and how many explosions have happened by people dropping inspection lamps in to pits?
So it's only inspection lamps that cause explosions
i would expect pits to be at least a zone 2 area now so there shouldn't be any standard type portable inspection lamps used
Rather makes a nonsense of your previous comment
Never used any Pyro terms that came with a tub of vaseline
I always thought the tub of lubricant that came in the packet of ends was to help ease the pot on to stop the cable twisting. How many times you heard the screeching noise where someone f**ker is forcing the pot on.
On the bigger sizes I've always used a piece of 25mm conduit as a stripping bar
.....Why have BICC provided a small tub of vaselin with a pack of 10 terms for the last 30 years. I've not always used it but when I have, a tiny bit on starting the strip hasn't made the slightest bit of difference to the integrity of the stuff....might do if your stripping an inch but I doubt it.
Used BICC's MICC for donkey's years, never seen a tub of vaseline in any of the gland/pot seal packs, The MICC seal packs we are using today on this project, also do not contain pots of vaseline.
Vaseline has a multitude of uses...
I've never used it with micc, I have used it on bus bar joints, isolator switch blades and fuse carrier blades.
A damn site safer than that Castrol green switch grease. That was carcinogenic.
On the cement plant we didn’t use any lubricant at all on switch blades. If the dust got in it would set and the switch couldn’t be opened. I was doing pull ups on an EE 800A switch fuse and still couldn’t shift it.
For busbar joints and many other connections it’s great stuff.
Not used it for a while, but it was the norm during my apprenticeship. My favoured stripping tool was a piece of 1/4 inch rod with a cut into one end and a handle bent into the other.
I never ever like the new fangled pot crimping tool that was introduced in the 70's, I always preferred the screw-on pots. The straightener was a great tool for a real nice finish.
IMG_0439.JPGMade thousands of the them off over the years. I'm very surprised many experienced lads haven't come across plastic vas tubs. They came in the packet with the terms.
Reply to Pyro in the UK Electrical Forum area at ElectriciansForums.net
