G
Guest77
Come on now fella, you should be well aware the Elderly feel the cold more than the rest of us chuckle.It's not even cold yet tel - big girls blouse comes to mind :smartass2:
you mean try using your arms and get your wheel chair moving.try getting up from your laptop and walking around! :clap:
Thought you'd be used to the cold Tel. I was driving between jobs this afternoon and the aircon in the car was struggling with the heat. I was on the coast road and when I came to a nice quiet spot I pulled over, stripped off and took a run into the sea. I was in the water for less than a minute and it was so cold I was already numb from the waist down so I know how you feel.
**edit** I just read this post back and something doesn't sound right.
A sh1tty job.......I got called out to a pump blocked .... they forgot to mention it was a cesspit pump, normally I refuse but was a treck to job so did it ... everything in washer after had to strip it down :shout:
A sh1tty job.......
Get a dog, a big active one. That'll get you on the move!try getting up from your laptop and walking around! :clap:
The kinda job I would normally have turd down.I got called out to a pump blocked .... they forgot to mention it was a cesspit pump, normally I refuse but was a treck to job so did it ... everything in washer after had to strip it down :shout:
Don't give up the day job!!!The kinda job I would normally have turd down.![]()
I think you missed your vocation, you should have been in the tourist industry as an ambassador for you areaits nice up here. rarely goes below zero.
and not much snow. where I come from it will snow, dogs will sh*t on it, it will melt a bit, got covered with road gritting mess, more snow, more sh*t, then it all melts down in the spring...
