and i always though that i was the missing link.The updated version of Part M added this little gem....
An accessible main switch in the external meter box (preferably provided by the DNO) becoming mandatory would be a very good idea in my opinion
ceiling height would be OK in geordieland. they can reset while having a bath in the sink. :6:
Ask yourself
if you could comfortably work on the CCU for any extended period. Accessibility includes maintenance access.
Yes, customers hope to locate CCU as unobtrusively as possible, that does not mean we should not try and get them right for working on them and regular RCD testing by customer.
4 posts on the trot.you got the runs?
if you need a thermostat to warm her up, you're not doing it right. " brace yersen fatty" is not ideal foreplay.
Not such a good idea when you come back home from yer hollys and find the food in yer freezer has gone off cos some little scallywag turned yer leccy off at the switch in the ootside cabinet.
I take you are talking about DP isolator, it is NOT, mandatory to fit one.An accessible main switch in the external meter box (preferably provided by the DNO) becoming mandatory would be a very good idea in my opinion
