K
Kingston555
Hi all. Just a quick one: are you allowed to run a cable (twin and earth) through the space under a bath tub, which still constitutes zone 1?
I thought under the bath was out of zones IF you could only access it with a tool? Screw the bath panel shut [emoji38]
You do need to unscrew the panel to get it off.
Thank you gentleman. You've made a whole lot easier.
Peace and love!
It ain't though is it? The area under the bath, assuming that it needs a tool to access, as in this case) is not a zone. It has to be passing through a zone, not the room in general.
It changed when the byb came out its now zone one all the time now
That's what I was thinking but couldn't be bothered to consult the book after a hard day of work:), same goes for cabling above the bath or shower room in the loftspace ?
Kingston555,
Deleted member 26818,
