M
Marvo
The tests on the earthing and neutral-earth voltage is something you'd have to get a sparky in for, you need special test equipment as well as the obvious hazards of having to make live tests on the incoming supply.
225 megs a second....Jesus.... are you serious? I don't think our national backbone network runs at that speed. I just upgraded to 2 meg ADSL at home and that took some pulling of strings.
Unless you have serious noise on the line then yes I would say it rules out the fixed wiring.
What adapters are they?
@Andy78 I've had good success, I wired a garage 120m away from the residence, it synced fast enough to browse/ YouTube etc.
I use them at home extensively as all my walls are solid so wifi drops out very quickly.
You have to remember that's it's fibre coming into the router, hence the fast speeds. A powerline adapter can't produce the speeds that fibre optics can. You would be lucky to hit above 60mbps, unless your running servers I can't see the need in a domestic property for +60 speeds.
This is a well known problem, when using powerline adaptors in houses with RCD's and / or RCBO's
Best results are installations without RCD's or RCBO's
Before I connected my hard wired LAN, I had about 7 powerline adaptors around the house - they are Devolo units and their "dashboard" would show the speeds between different units.
All our circuits are on RCBO's so we had some slow links and some ultra fast links.
The powerline manufactures deny the issue exists but it does.
My FIL's house has 2 x CU's, each with an upfront RCD - its not possible to get a decent connection across the 2 fuseboards...
