Just don't go hammering a nail in to the wall for the painting the missus wants you to hang.
reminds me of my earlier alarm days. foil on shop windows. now that was an art in itself, double folding the corners, masking off, 2 coats of clear varnish over. recently spotted some i did in 1982. still working fine.
This is great! I can see a massive new-year cheque,coming my way,when i suggest an innovative network distribution design,to the DNO.
Along the same principles,i will be suggesting that they use double and triple road marking lines,to add supplies,with self-adhesive links,off,to each new property.
I will,of course,be obtaining preferential bidding options,on all the DNO's redundant excavators and equipment.
This time,next year,Rodney....
This is something,you could only know,if you had recently broke in,and been successfully prosecuted :):):)
they could replace all them nasty double yellow lines with copper strips. tap off the supply to properties with an earth rod banged in by the kerb. trolley buses could then be re-introduced with swingin pick-up arms to run along the strips, instead of those unsightly overhead cables.
