the pict
Mentor
What are you chaps using for intumescent seal and chafe prevention on rear entry consumer units where the big oval hole(s) have been knocked out
Pict
Just make sure you install the cables correctly, ensure correct terminations etc, who needs intumescent sealing?
I go a bit overboard to be honest the building regs can be quite tight round our way with preventing the spread of fire so I usually mount the board on a bit of pink gyproc and make the hole coming in through the gyproc as small as possible then fill in between and around the cables with intumescent sealant I stick grommet strip round the edge of the knockout but that’s pointless as the cables will never be able to meet the edge of the knockout.
I went on a seminar when metal boards came out, representatives from the IET were sat at the front and said its not required, if the hole isnt almost full of cables ill seal, but otherwise i leave them
The risk is the spread of fire through the rear of the C.U. and what it is mounted onto eg non- combustible - wet plastered wall, pink plasterboard or plasterboard with a timed fire resistance.
I use lock brass locking nuts from behind the board and bring the cables from behind so there less chance of any cable being damaged .
And try and seal it.i have tried the grommet job that keeps coming when you pull the cables through.
