It's a relatively simple environmental test....if your hob,cooker or boiler uses gas....wind your neck in ;)
All for everybody to have the space and right,to peaceful complaint and protest,but during some recent long-term protest,at Irlam Moss,i had to regularly run the gauntlet of the colourful and vibrant camped masses...
Bit of fervent lefty banter,through the window...all polite...but i had noticed that nearly every van/shack,had some form of bottled gas,for cooking and a bit of heating. No probs...got to eat...chilly when sat about all day...
I asked a previously perky and pierced spokeschap,how he squared that irony...and got a continuous and vocal assault,of the foulest manner...his tongue stud nearly flew out :rolleyes:
If he couldn't form a reasoned argument,he should shut the frack up :rolleyes:
Pumping water into the ground under high pressure to fracture the rock to release gas....I’m sure someone will be along with a better offering but that’s essentially it....
For ‘water’ change to ‘nasty chemical cocktail of acids and hydrocarbons’ which apparently will have no effect on the water table .....until it’s too late that is.
I’d have to bow to your superior knowledge on this one Alan, I was only attempting a rough outline for gaz :)
Fracking has been around since the 1940's, its not a totally new method of extracting hydrocarbons. Gas is also the cleanest (C02) of the hydrocarbons. I dont think fracking is as dangerous as its being reported and is being hyped up. Much of the content in the videos posted above "Gaslands", and now theres a "Gaslands II" have been debunked. If theres gas there then the Lanacshires should keep it for themselves, I think every house should have a wind turbine or solar for personal consumption for lighting and such thats my thoughts on it.
Listen,it's much more technically advanced than that...they have top-kill,blind shears,annulus plugs...contact BP and ask em' if it's gear worth havin'?
:rolleyes:
PS Just had to edit this,as i remembered what was the branch of industry,whose failure contributed greatly to that disaster...i'll give you a clue,it wasn't plumbers,welders,drillers,geologists or pipe-fitters...:eek:
Fracking in Lancashire......
Electrician Talk Forum
Tags Tags
None
Squid,
buzzlightyear,
