G
GBDamo
Any of the site historians like to explain what this is all about?
It looks like one side is a 40A main fuse but the other, exposed, side attached to the 15A switch?
By the way it was open when I got there, honest.
Need the DNO in to put in an E7 meter and teleswitch, if that's how they still do it.
In the cutout you've got a 40A fuse and a solid neutral link which has been put in to replace the original neutral fuse.
Not sure what the 15A switch fuse is doing.
Is there a BS number for this type of fuse, can't see anything on the housing.
Before British Standardisation?
The D.N.O don't fit meters.
You'll need the energy supplier to fit that, but you'll need the DNO to change the cast iron cutout first.
Cheers, DNO is a cover all for 'not my responsibility' in my language but you're correct.
