which wire strippers are the best out of these?
Yes good setI find these the best
I have used the CK "automatic wire stripper" and it is great for PVC T&E cable. Not very good for XPLE insulation, and not so great for round cables, also I used an angle grinder to remove the palm-biting parts of the inner handles.which wire strippers are the best out of these?
I end up in attics a lot, so try to take the minimum amount of tools with me.I have a similar cutter, but that has two stripping holes and not the other features, but found it annoying trying to cut wire and it getting only partially cut unless I carefully positioned it at the outer half of the blades.
You're right with the cutting width being a bit short, perfect for 1.0 mm / 1.5 mm t&e.
The cutter for the screws is brilliant.
