HiWell done, you got the result!
Can you tell me what this component does please? Its not wired into the generator system and its missing from the stator on my bike...I believe that is the problem
It was probably a coil for charging the battery.Hi
No battery on the bike, this is standard for this bikeIt was probably a coil for charging the battery.
Yes, which is why it doesn't need the extra coil.No battery on the bike, this is standard for this bike
I fitted the ac voltage regulator but it still popped the bulb...confused dot comYes, which is why it doesn't need the extra coil.
Are you sure you wired it correctly, did you measure the voltage at the lamp.I fitted the ac voltage regulator but it still popped the bulb...confused dot com
HiAre you sure you wired it correctly, did you measure the voltage at the lamp.
AC regulators connect to the generator winding so that excess voltage can be dumped to prevent bulbs blowing.
When fitting an AC regulator simply connect the yellow wire to the feed from the generator and earth the case.
The regulator case must have a good earth directly to the generator. Where there are two
wires from the loom, one will be earth, the other will connect to the regulator’s yellow. You’ll need a multimeter to check which is which or the wiring digram.
AC systems require the earth to be as good as the feed wire. Relying on the engine mounts is not good.
Where problems persist adding an earth wire to the regulator mounting bolt, direct to the engine case can help.
Poor earthing is the most common cause of problems.
Can you tell me the model of the bike /year engine etc.Hi
Wired as per rex wiring diagram and I ran a separate earth to the reg from the stator .
I'll have another look this week at it, and get my meter on the lighting circuit, see what I'm getting
Thanks for the advice
1976 honda mr175 elsinore this is the wiring diagramCan you tell me the model of the bike /year engine etc.
Unless the regulator is duff or the wiring is wrong, it should work.1976 honda mr175 elsinore this is the wiring diagram
Regards
