baza890
Trainee
Need to get a voltage and continuity tester I do like the fluke one from screwfix but it's a little out of my price range for now. anyone know any good budget alternatives?
Try here, they have plenty of options at better prices than Screwfix.
Personally I prefer DiLog but their cheapest offering, the Martindale, is absolutely fine.
good shout thank u mate
Fluke T90 Voltage/Continuity Tester
Dilog Combivolt 1 - DL6780 Voltage and Continuity Tester
Martindale VT25 Voltage & Continuity Tester
Which one do I get or is there any better ones for similar price?
Hi baza
When you first asked the question last week, I had in mind (prob incorrectly) that you were asking about a two pole tester for checking circuits are dead before working on them. The martindale I suggested is really mainly for that, and for very basic continuity. In addition I use a multimeter for fault finding etc.
If you want a safety tester that will also double up to do measurements (ie instead of having a multimeter as well), then you need something more advanced than the Martindale.
Personally I think the advice to go for the Fluke T150 is good, but I appreciate it's expensive.
If you check 'sold' prices on eBay, you can find a few that sold for £60 to £80 fairly recently. There is a risk in buying such (I wouldn't recommend the Chinese source) but at that sort of price you could probably sell it on if there turned out to be a problem! You might be able to afford to get it calibrated too!
I've bought literally thousands of items from eBay, and very rarely had a problem, even with electronics (eg TV circuit boards, appliance spares) although these days eBay prices can be higher than online retail.
Ebay bargain Computers, tablets, phones I keep away from!
Hi baza
Ok so If I buy a t150 I wouldn't need to buy a multi meter + a two pole voltage&continuity tester?
I'm not too fussed on buying a two pole tester atm, I'd rather just buy a budget friendly multi meter for £10 and under lol prob won't get one for that much and test what I need to for now, I can buy the latter in the future. If it comes down to the mm being like £20 then i might aswell just throw another 60 on that and buy the t150
What exactly do you want/need the tester for?
A £10 multimeter will almost certainly not meet the safety requirements for use on LV, but would likely be ok for ELV.
need to test socket readings to figure out if a circuit is on a ring or radial
If you mean by doing resistance tests, you would need a MFT or low resistance ohmmeter for that, which typically give readings to 2 decimal places.
I believe the Fluke T150 only has a resolution of 1 ohm, so your reading would be either 0, 1, or 2, not giving the accuracy you would need.
A cheap multimeter wouldn't really be suitable either.
A bit of (out of date) discussion here a few years ago: Cheapest Multimeter (low ohm - in - Electrical Tools and Products - https://www.electriciansforums.net/threads/cheapest-multimeter-low-ohm.190178/
can't i just use a dbl pole volt tester to see if the circuit is a ring or radial, it's a b32 mcb with 2 wires going into the Cb but, there's 3 sockets with single wires (1 socket use to have a switch spur for a floodlight but a electrician removed that recently since we didn't need it anymore) and then one socket with 2 wires entering it.
one of the sockets was a single gang which was just removed it's the only one wire that's going into a junction box which is above the floorboards i think it was just used to extend the cable to put the socket higher, I was thinking if i trace that wire back to where it's going and just get a longer length 4mm cable and install the socket on that on the opposite wall which is where we need it.
You may as well find a cheap MFT for now, and it will also give you the experience of using one.
I was overthinking what you might be wanting to do in the longer term.
If you just want to do continuity tests, say with a wander lead connected (eg to an isolated wire) at the CU, and checking at your socket or JB which wire goes to that, any of the two pole testers will do that, even the Martindale.
And the advantage of having a 2 pole tester over a multimeter is that you can properly check a circuit is dead before working on it, whereas a multimeter is not the tool for that.
ok I don't think I'll be going for the multimeter atm, ideally a two pole tester, don't really want to spend 100 on a t150, the ebay ones I can't seem to find a legit seller or trusted source, maybe i'm just being cautious. Would the t90 serve the same purpose as the martindale or in what way is it better
The Martindale does a couple of things:
If you probe a 'dangerous' over 50V it buzzes and lights up LEDs indicating the voltage in steps.
It beeps when you touch the probes together, ie continuity. Eg typically does that when you probe between N and E.
The Fluke T150 does all those things, plus it has a LCD display that shows the voltage, and it can also show resistance on that display - low ohms with 1 ohm accuracy. It also has a switch to give a greater load on the circuit being measured to reduce ghost voltages. There are probably other features I've forgotten. Its all in the details online
baza890
Trainee
birmingham
Trainee Electrician
Anyone know good voltage & continuity tester?
baza890,
Brother Blue,
