Hello I want to run a 220 for a dryer hookup its in a unfinished basement and about 15 to 20 feet away. My question is can i run 10/3 Flexable conduit the ones with the wires installed in the pipe already. Can i run that fron the breaker box and just put the conduit hooks to secure it to the basement wall until i get to the spot i need to put the juntion box for the 200 Hookup? Thank you
Hello I want to run a 220 for a dryer hookup its in an unfinished basement and about 15 to 20 feet away. My question is can i run 10/3 Flexable conduit the ones with the wires installed in the pipe already. Can i run that fron the breaker box and just put the conduit hooks to secure it to the basement wall until i get to the spot i need to put the juntion box for the 200 Hookup? Thank you
If you do this project then the flexible conduit needs to be secured and not subject to physical damage. Good luck
