I am a trainee electrician and have nearly completed my level 2. Just curious as never come across it before but can I run a single length of 1mm T+E from my ceiling rose loop terminal to an outdoor security light and then rely on the pir to go on and off? I Don't want a switch.
Does it have to come from the bathroom light?
Any other light, you could have this isolation switch on the ceiling, or if routed through an attic, anywhere hidden like in an airing cupboard.
This gives the useful isolation before any external wiska box.
The closest point is in the entrance hall, it's not from the bathroom light, either way a wiska box or switch would be needed external, I'd rather have minimal joins and still be aesthetically pleasing
Sorry. I thought a bathroom was mentioned earlier??
It’s entirely up to you. As explained, there’s no requirement for an isolator, but it would be useful in case of a fault in the external light. A DP switch would isolate a N-E fault as well as L-E.
That's fine I appreciate the suggestion, I think I'll go with the weatherproof DP Switch and seal it etc keep it simple.
I've got similar already in place that has an FCU from the kitchen ring leading to an outside socket then a fused switch from that (with a down rated fuse) to an outside light but that isn't an option this time, thank you everyone for the help 👌
If this is an outside light mounted high up,
i see no point in putting an isolator on the wall that you need a ladder to access. a junction box with a drain hole in it is likely to last for 10 years or more.
if you are really wanting an isolator, put it in the loft where it is easier to get to.
My take would be that if you're going to put a junction box outside, you may as well put a switch in it.
Going into an attic in the dark, looking to isolate an outside light so that the lights can be re-energised wouldn't be ideal.
It maybe that you would need steps/ladders to get into the attic anyway.
I guess it's all down to the layout, ideally the outside lights would be on their own circuit anyway.
Seems a lot of effort just for a single light to put it on its own circuit.. I accept that if there were several lights that may be a better option.
as you say, layout is everything,
if it were at my house, getting on a ladder outside in the dark to go 15 or 20ft up with nobody to foot it on slippery slabs would be a big NO, popping the loft hatch and going up with a torch and step ladder would be ok.
for the purpose of clarity, the switch is not required to keep the circuit within the regulations and in many cases it is simply better to omit it instead of working out some convoluted way of installing it.
it is in my opinion, up to the installer to decide unless the customer has a particular requirement (in that case they will almost certainly know where they want it fitted)
You haven't said how high the sensor / light is intended to be, if it's between the floor boards to the outside you could put the switch in the hallway just below ceiling height with a bit of mini trunking.
You haven't said how high the sensor / light is intended to be if its between the floor boards to the outside you could put the switch in the hallway just below ceiling height in with a bit of mini trunking.
Apologies it will be around 7/8 ft it's above the front door to light up the gravel drive way when approaching it will be run outside from below floorboards in upstairs bedroom (above entrance hallway) trunking isn't wanted however due to aesthetics 👍
Seems to be back to square one then, as I doubt you will be putting an isolator in the attic.
Also, some sensors need a switch for some functions to work, although remote control ones are quite common these days.
What type of consumer unit is it ? rcd /rcbo dual rcd ?
