Ah just run the cable straight into the wiska box as per the original plan?I wouldn't fit a switch.
A wiska box has just as much chance of ingress as a decent switch housing.I would not use an external switch it gives you a double chance for water ingress.
Yes this is true I considered this later.A wiska box has just as much chance of ingress as a decent switch housing.
The closest point is in the entrance hall, it's not from the bathroom light, either way a wiska box or switch would be needed external, I'd rather have minimal joins and still be aesthetically pleasingDoes it have to come from the bathroom light?
Any other light, you could have this isolation switch on the ceiling, or if routed through an attic, anywhere hidden like in an airing cupboard.
This gives the useful isolation before any external wiska box.
That's fine I appreciate the suggestion, I think I'll go with the weatherproof DP Switch and seal it etc keep it simple.Sorry. I thought a bathroom was mentioned earlier??
It’s entirely up to you. As explained, there’s no requirement for an isolator, but it would be useful in case of a fault in the external light. A DP switch would isolate a N-E fault as well as L-E.
My take would be that if you're going to put a junction box outside, you may as well put a switch in it.If this is an outside light mounted high up,
i see no point in putting an isolator on the wall that you need a ladder to access. a junction box with a drain hole in it is likely to last for 10 years or more.
if you are really wanting an isolator, put it in the loft where it is easier to get to.
Seems a lot of effort just for a single light to put it on its own circuit.. I accept that if there were several lights that may be a better option.My take would be that if you're going to put a junction box outside, you may as well put a switch in it.
Going into an attic in the dark, looking to isolate an outside light so that the lights can be re-energised wouldn't be ideal.
It maybe that you would need steps/ladders to get into the attic anyway.
I guess it's all down to the layout, ideally the outside lights would be on their own circuit anyway.
Apologies it will be around 7/8 ft it's above the front door to light up the gravel drive way when approaching it will be run outside from below floorboards in upstairs bedroom (above entrance hallway) trunking isn't wanted however due to aestheticsYou haven't said how high the sensor / light is intended to be if its between the floor boards to the outside you could put the switch in the hallway just below ceiling height in with a bit of mini trunking.
Seems to be back to square one then, as I doubt you will be putting an isolator in the attic.Apologies it will be around 7/8 ft it's above the front door to light up the gravel drive way when approaching it will be run outside from below floorboards in upstairs bedroom (above entrance hallway) trunking isn't wanted however due to aesthetics![]()
Split board with RCD all on MCB'sSeems to be back to square one then, as I doubt you will be putting an isolator in the attic.
Also, some sensors need a switch for some functions to work, although remote control ones are quite common these days.
What type of consumer unit is it ? rcd /rcbo dual rcd ?
