I am a trainee electrician and have nearly completed my level 2. Just curious as never come across it before but can I run a single length of 1mm T+E from my ceiling rose loop terminal to an outdoor security light and then rely on the pir to go on and off? I Don't want a switch.
Split board with RCD all on MCB's
It definitely needs an accessible isolator as a fault on it will cause half the board to lose its supply.
If it were me I would endeavour to have the dp switch inside but you haven’t that option.
You’re going to have to use a junction box outside so it may as well be an isolator, as long as it’s a decent one it will probably out last the Pir sensor/light.
I’m sure in the future someone may appreciate having one rather than not.
It doesn't definitely need one.
I'm gonna have to disagree on this one mainline. Unnecessary if we're going off regs. The point of isolation for the circuit is clearly the breaker in the CU no specifics to light isolation in this setting.
I didn't say it definitely needs a switch installing, I said “It definitely needs an accessible isolator as a fault on it will cause half the board to lose its supply”
I also said "Doesn't matter where it is, whether it's in the Cu or elsewhere, it still definitely needs one"
As a fault on any circuit will cause half the board to lose supply.
Not strictly true as an L to N fault won't trip the rcd just the related mcb.
There is no requirement or regulation to have the isolator just for the outside light..... its only a "nice to have"
I didn't say there was, but there is a reg to have a means of isolation, as already said.
All you are doing is completely confusing the OP who is a trainee and I'm not sure why. His original plan if perfectly sound and that is all they need to do.
Thanks westward, it's reassuring that my thoughts and plans are actually genuine and right. Obviously a lot to learn still but every day is a school day and I try and brush up the weak areas of my knowledge as much as I can! I've already realised there's a lot of crossover areas or grey areas where there is a lot of different opinions and ideas on certain things which obviously does confuse me but as long as what I do is safe and obviously within the regs I'm happy 👍
